I'm trying to piece together the info I'm finding on a few items I want to fix on my 250ES. I have one of the 250SX service manuals I found linked here to go by (I assume the engines are nearly identical.)
Right now it's my belief the timing chain needs replacing. It started a rpm matching clicking knock a while before I parked it, and from all the descriptions it seems to be the most likely issue. I also just pulled the tensioner and when I put it back in there was very little adjustment in it.
At the same time I think my one way clutch bearing is shot. As long as I've had this bike the kick start never worked, and it seemingly slips into neutral if I let the rpm's drop.
So what all do I need? As in replacement parts and tools.
Timing chain and guides.
Gaskets for the clutch cover and head?
New one way bearing.
Wheel puller (for centrifugal clutch?)
I think I replaced the centrifugal clutches a while back when I rode it more. But I didn't touch the disk clutches, should I plan to replace those while I'm in there for the bearing, or wait and inspect them?
How much of the top end will I need to remove to replace the chain guides? Just the very top "head" section? I don't really want to mess with the cylinder and rings.
I pulled the clutch cover this evening, looks daunting but I take it that it's not so bad.
Thanks for any help, tips, and assistance. I've never dug this deep into an ATC before. I am searching through old threads, but given I'm doing 2-3 things at once I want to see if I can't get some logic checking before I get in too deep.
