Just looking for some feedback as to where is best to buy front and rear rims for a 1985 250r. what makes you guys prefer and offsets? thanks
Mixing gas and haulin' ass
1984 ATC 70 x2
1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
1985 ATC 250R-stock
currently looking at the douglas A5 wheel, is it better to go with the 8x8 3.0+5.0 of the 9x8 3.0+5.0? I'm no expert with rims and so if someone could explain the difference it'd be much appreciated
1984 ATC 70 x2
1985 ATC 250R-stock
For front rims you have the option of the 11 inch rim in either the original gold, from EBAY or otherwise. Douglas makes a chrome front rim but the 11 inch rim leaves one with limited tire choices.
The other option is a 10 inch custom rim from xowner or from Douglas which opens up more choices for tires. Xowner does group buys and pretty sure Douglas does not stop production to make just one so it may require a batch. The Douglas 10 inch front rims may be on EBAY but I get mine from xowner.
8x8 is eight inch rim, eight inches wide. 3.0 is the offset from the back of the rim flange to the outer edge or the rim, the 5.0 is the rim flange to the outward facing side of the rim.
I assume the 9x8 is a nine inch rim as the offset is the same, and would require a nine inch tire. Where as the eight inch rim would require an eight inch tire.
The style/brand of rear rim is really dictated by the terrain you ride and how you ride your machine.
Okay awesome! Thanks for the quick reply Mr. Clean! Really helping me out
1984 ATC 70 x2
1985 ATC 250R-stock
And as for the front hub is it able to be sandblasted and re powder coated?
1984 ATC 70 x2
1985 ATC 250R-stock
Currently Owned
1986 Yamaha Tri-Z 350???
1985 Honda ATC 70
1985 Honda ATC 250R
2006 Suzuki LTR450
2005 Suzuki LTZ400
2005 Polaris Predator 50
2004 Polaris Predator 90
2-Honda Trail 90's (need to be brought back)
Feedback Thread http://www.3wheelerworld.com/showthr...-for-New2Tri-Z
Do you guys know the name of the 11' front wheel from douglas can't seem to find any on rocky mountain tav
1984 ATC 70 x2
1985 ATC 250R-stock
Cannot find a new one, but found this tire/rim setup.
http://www.ebay.com/itm/HONDA-ATC-25...62ece6&vxp=mtr
Douglas is still making 11x6 front rims, if anyone is looking to buy some you've gotta contact douglas rims and the part # is 017-02
1984 ATC 70 x2
1985 ATC 250R-stock
would a 22x11-8 tire fit on a 8x8 rim or would it be better to go back to original size with a 9x9 rim and get 20x10-9 tires?
1984 ATC 70 x2
1985 ATC 250R-stock
It will fit just fine. 22" is a little tall for my liking, but I like them wide. I personally would run the 20x10x8, thats what I run on My Tri Z and my 450R (paddles and holeshots).
Currently Owned
1985 Honda ATC 70
1985 Honda ATC 250R
2006 Suzuki LTR450
2005 Suzuki LTZ400
Damn those are nice
1984 ATC 70 x2
1985 ATC 250R-stock
22" tires are nice if you need the ground clearance. Or if you're looking to get the most top end speed out of your machine. It all depends on what terrain and style of riding you prefer.
85 Kawasaki KLT 160
85 Kawasaki KLT 110
82 ATC 70
2000 Scrambler 500
