Results 1 to 15 of 16
Thread: Tig Brazing
    Billy Golightly's Avatar
    Live Oak, FL
    15,066
    Tig Brazing
    Anyone ever seen in person or used this method? Was thinking a future pipe might look cool done up with it.
    Michigan UP
    1,005
    Polished stainless pipe done like that would be sweeeeet
    Mar 2008
    EastGreenbush, newyork
    3,494
    looks wicked trick. Would look awsome on a pipe. Dont know about for structural strength though, isnt brazing, even with tig, just a surface bond? I dont think you get the same burn in on the base metal with a braze. Looks like maybe some silicon bronze rod, which is super tough, and will bond dissimilar metals.
    Mexico
    9,012
    Hey Billy,
    I've TIG soldered steel with brass rod before on some pretty stressed parts (lower drag bar mounts) My TIG mentor swore it was a very strong way to attach things to each other, but like the guy in this video say, it won't be as strong as steel to steel, but I'm guessing the welds won't stress crack as the brass is softer. I don't think brass paints well, but for a pipe it should work great. In fact I believe many spring hooks on 2 stroke pipes are brazed on.
    http://www.youtube.com/watch?v=mhlAO2WIFKE
    It sucks to get old
    1,641
    On a sextional exhaust, think it would break apart.Once it starts your screwed.Especially on a.pipe like your building.Not worth the chance.One thing I would have done is purge welded your pipe.Plus used 309 SS tig wire.It would turn out nice and be strong.
    Oct 2013
    Wherever I May Roam
    3,757
    I am just learning to use a TIG but I can't imagine brazing a pipe, that's pretty thin material. As stated above if it starts to open up you're done. It would look beautiful though...
    Feb 2008
    (southern) Wisconsin, USA
    974
    Fusion weld with gas maybe, Billy?
    My son and I did some playing around with our oxy/propylene smith this past weekend. I was surprised how well fusion/no filler worked on an old roached out FMF. Kenny Roberts fusion welds and then hand pounds each section smooth (no filler). Think he uses oxy/acetylene though. He only brazes the exhaust port bell and spring hooks. Awesome work you do! Love watch'n!
Name:	200R pipe (new) 2.jpg
    Live Oak, FL
    15,066
    Thanks for the feedback everyone. I ordered a small 1lb package of Silicon Bronze rods from McMaster to try and do the bracketry on the pipe with as a starter - we will see how that works out before I get any more ambitious
    Live Oak, FL
    15,066
    Pretty good video here I found;
    https://www.youtube.com/watch?v=nm8Fn2ou_nw
    Mar 2008
    3,494
    i know that rod is not cheap, what mcmaster get you for it?(too lazy to look myself)
    Oct 2007
    Minneapolis mn
    4,067
    We did a fair batch of silicon bronze with the tig back at the street rod shop... I think it would hold up on a pipe...
    Live Oak, FL
    15,066
    Quote Originally Posted by aldochina View Post
    About $20 a lb is what it worked out to be. I didn't buy more than a lb
    Apr 2006
    London Ontario, Canada
    1,192
    We use that rod all the time at work. I seen the welders braze 26ga material together. You can also use a stick welder as the heat source, but need a carbon rod instead of the regular welding rods. I have patched up a few mufflers with it and haven't had any problems.
    R.I.P. Sandpuppie, you are greatly missed!
    May you rest in peace Jeswinehart, deeply missed, never forgotten....
    Feedback thread http://www.3wheelerworld.com/showthr...ight=tapper190
    Surprise, AZ
    2,430
    There were motorcycle frames that were brazed in the 1960" & 70"s (American Eagle & Rickman to name a few) They didn't have any problems.
    Many bicycle frames are still brazed today, including downhill bikes.
    Many old 2 stroke aftermarket pipes had brazed exhaust flanges, pipe spring holders, mounting brackets and mounting nuts.
    An old welder told me it helped with vibration issues.
    As soon as Bill's pipes started Migging everything it seems everyone followed.
    fastatc70 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2012
    Northbrookfield, Ma
    166
    I have used Harris 56 to tig weld with. Mostly socket welding dissimilar metals like steel to copper or copper to stainless ect. The next time I start up the tig welder I will try to butt weld 1.5 SS tubing. Test it's durability.
    Trikes:
    1985 ATC 70 mod to 184cc
    1984 ATC70 mod to 124cc
    1983 ATC 70 Xmas restoration
    Quads:
    1986 TRX 250R
    2002 TRX 400EX
    2- LT80 for the kids
    1986 LT 50
