Results 1 to 15 of 19
Thread: '85 250R countershaft rotation ease
    pismorat's Avatar
    pismorat is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2005
    San Diego
    207
    I'm afraid to ask this, but I don't want to go further with my rebuild with it potentially being wrong. I installed new crankshaft bearings and seals, put the tranny back together, and joined the cases. I'm just starting to rebuild the right hand side and noticed that the countershaft doesn't spin without using pliers on it. The shift drum moves to 1, N, 2, 3, 4, 5, & 6, but it feels tighter than I think it should. Anyone know if I should be able to spin it easily by hand? I guess this is what I get for rebuilding it ten months after I tore it down!
    '78 Honda ATC90 (132cc)
    '83 Honda ATC70 (88cc)
    '85 Honda ATC250R
    '86 Honda TRX200SX
    '04 Honda 400EX
    '73 Honda Trail 90
    '01 Honda XR70R (125cc)
    '16 KTM 500 EXC
    Jan 2011
    Choctaw, OK
    2,755
    ya it should rotate freely.
    pismorat's Avatar
    Dec 2005
    San Diego
    207
    Dang it! So what could I have assembled wrong? Something obviously is making it bind. How many times can a center gasket be used if it's never been run (just had the cases bolted together)? I can see this being a problem.
    '85 Honda ATC250R
    '86 Honda TRX200SX
    '04 Honda 400EX
    '73 Honda Trail 90
    '16 KTM 500 EXC
    Jan 2011
    Choctaw, OK
    2,755
    As long as the gasket isn't torn, reuse....
    pismorat's Avatar
    Dec 2005
    San Diego
    207
    Split the cases today. The second I loosened all the bolts the cases separated a few thou and the countershaft freed up. I tightened the one bolt closest to it and it got tight again. Does anyone have a really good exploded diagram of the countershaft gears and shims? I have the manual, but I apparently that didn't help me build it right...
    '85 Honda ATC250R
    '86 Honda TRX200SX
    '04 Honda 400EX
    '73 Honda Trail 90
    '16 KTM 500 EXC
    Jan 2011
    Choctaw, OK
    2,755
    You probably have something backwards or the shift drum pins not aligned/mixed up....
    Blossvale NY
    4,567
    I'm thinking a misplaced trans shaft shim.
    It should rotate freely, but with a moderate amount of smooth drag..bearing drag. It shouldn't spin like a dry roller skate wheel, and it shouldn't require a pair of pliers either.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 200ES Big Red
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    pismorat's Avatar
    Dec 2005
    San Diego
    207
    I haven't pulled the tranny out of the left case yet, but there are three small shims on the end of the shaft that would space it against the bearing. Two are the same as eachother, the other has two small grooves in it (this is the one I'm thinking is misplaced). The schematics don't show these specifically, only as washers...
    '85 Honda ATC250R
    '86 Honda TRX200SX
    '04 Honda 400EX
    '73 Honda Trail 90
    '16 KTM 500 EXC
    Blossvale NY
    4,567
    I really wish I could remember exactly how they go so I can help you. But to tell you the truth, I just don't remember exactly because it's been almost 2 years since I have had one of my bottom ends apart.
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    May 2009
    S.E. Michigan
    1,250
    I think you need to take a closer look at chapter 8 in the manual. It shows the individual components both at the front of the chapter, and again on page 8-9. I don't see three washers / shims together anywhere.
    - Frank
    1984 200ES Big Red
    1985 350X (x2)
    1986 350X
    1986 250SX
    1984 Auto-X
    1984 ATC70
    1985 ATC70
    pismorat's Avatar
    Dec 2005
    San Diego
    207
    Yeah, I think what happened...I can see the notched washer under the outmost gear. I repositioned it, but then having the two washers after that outmost gear is wrong. I think one of those goes on the other side of the shaft next to the left case bearing. I'll pull the tranny tomorrow and see what happens!
    '85 Honda ATC250R
    '86 Honda TRX200SX
    '04 Honda 400EX
    '73 Honda Trail 90
    '16 KTM 500 EXC
    Blossvale NY
    4,567
    Quote Originally Posted by pismorat View Post
    That sounds likely to be right!
    Trikes:
    '85 ATC 350R
    '85 ATC 250R
    '86 ATC 350X
    '85 ATC 350X
    '84 ATC 125M
    '85 ATC 110
    '85 ATC 70/110
    pismorat's Avatar
    Dec 2005
    San Diego
    207
    In thinking it over last night, that second washer has to go somewhere else. It won't fit on the counter shaft side, so I'll have to keep looking.
    '85 Honda ATC250R
    '86 Honda TRX200SX
    '04 Honda 400EX
    '73 Honda Trail 90
    '16 KTM 500 EXC
    You know better now don't ya!!
    Use your cell phone and video and record just the few times it gets hairy......
    I still do it.
    Edit - I haven't done an 85/86R for awhile. I guess they have a gasket and not just 3Bond??
