Originally Posted by
RoscoW
250R's produce a lot of noise from the counter balancer that sounds like rattling. These are older engines and the straight cut gears that drive the balancer will develop some increased backlash over the years. If the noise doesn't change with pressure on the clutch lever I would suspect the balancer is the sound you are hearing. they can be rebuilt with new bearings but the gears are discontinued.
Ross..
So I have read up some on the counter balancer and kind of understand it now, the clutch is very easy to pull and doesn't seem to do anything at all idling or revving, looks to be a common problem so will check it out and also the clutch cause I am pretty sure it isn't working. The sound seems to be constant and doesn't change in loudness or speed up with revving the motor, just kind of gets drowned out buy the exhaust noise when revving the motor.
(Current machines)
1985 250r Atc
1985 350x Atc
1985 250es Atc
1987 250sx Atc
1981 185s Atc
1980 70 Atc
1984 125m Atc
1980 ct110 trail
