MY 85 250ES NEUTRAL SWITCH IS MESSED UP...I TRIED UNHOOKING THE 4 WIRES COMING FROM THE RIGHT SIDE OF THE ENGINE TO BYPASS IT BUT NO LUCK .... AANY IDEAS ?
250r dust runner
You say messed up, what are the symptoms?
"Roll on 3"
RIP Ol' Deuce
"Long Live the ATC"Building: ATCr125xRiding: ATC200sx"I am not a mechanic, mechanics get paid for this. I do it because I enjoy it."
4 wires????? Neutral is only one wire and it gets a ground when the tranny is in neutral. To bypass, all you have to do is ground that neutral wire. That enables the starter solenoid and turns on the neutral light.
when in neutral most of the time it wont get spark cause it thinks its still in gear..i don't have any dash light so I guess I need to figure out what color wire is the neutral wire.
250r dust runner
Damn, I was just fooling with that the other day and cannot remember the color. I want to say black with a green stripe but I am not certain. I am pretty sure that the diagram is in the manual all the way in the back.
"Roll on 3"
RIP Ol' Deuce
It should be a two wire plug, one wire red, one wire green. Jump the green wire to ground.
Rides:
1985 250sx
1982 ATC185s
1984 200es
Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
"Wear Limits Are Just A Suggestion"
