Results 1 to 11 of 11
Thread: weird electrical problem!!!
    Nov 2013
    NB canada
    67
    Ok so I traded something for a CT70 with a ATC110 motor swap in it. Runs pretty good. So I want to make the lights work again for night time riding, he told me the wiring works just needs a bulb. So I got a bulb put it in its slot and tried it before putting it back together and it worked, put the whole light mechanism together, doesn't work, take it out and works, touch it against the frame doesn't work then works again wen its not touching the frame. (Light mechanism is made of metal, see pic.. might make more sence lol) So Im figuring I have a short somewheres and theres electrical current throughout the whole bike. Wen I take the ground wire of the light and tough it on the frame it sparked. Now, Started looking in the wiring and everything looks good really but I found there was another wire bolted with the ground wire of the coil. I thought that was my problem, took that random wire out and started it, bike fired right up, at that time I had my light mechanism together and it was touching the fork I noticed it was sparking light crazy so I shut it off and now I have no more spark to the plug....!!! What just happen!!
    Could some one with more knowledge/experience then me tell me whats going on with this bike lol
    Thanks and sorry for the long story
    Heres a picture of that wire.. I was looking at the diagrams but can't figure it out!! What is it where does it go! The green one!
Name:	Screen Shot 2014-11-21 at 5.33.10 PM.jpg
    Miami,Fla.(305)
    808
    Its a ground terminal. And green is ground anyway. IT MIGHT be the one thats usually bolted to the frame at the coil? -with 1 of its mounting bolts
    Previously Owned:
    1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
    1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
    1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    1969 HONDA MINI TRAIL 50
    TRIKELESS
    Miami,Fla.(305)
    808
    Which harness do you have?
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Nov 2013
    NB canada
    67
    I have the 110 harness.. an for a little update I bolted that green wire to the frame and I have spark again, fired right up.. but the light is still doing that weird thing, on wen Its not on the bike and off as soon as the light contacts with the bike.. Where would I check for this type of problem? Thanks!!
    Miami,Fla.(305)
    808
    Hmmmm....Not sure?-pinched wire? look over the harness yet?... Or short in switch maybe?
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Mar 2007
    Hampshire U.K.
    536
    Have you tried swapping the wires on the light?
    ATC 70, ATC 250es, 1/32 ATC 250R
    1 person in 10 understands binary, the other one doesn't.
    Trikefest UK '08 survivor!
    May 2011
    eden,ny
    3,482
    swap the wires. It sounds like your voltage is running through the base of the bulb and grounding when you put it in the housing.
    Apr 2013
    snyder texas
    456
    X2 on reverse polarity also check what the green wire is spliced in to lots of bikes use black as ground and greens for something else
    you know whats right therefore you know what is expected
    Nov 2013
    NB canada
    67
    well it all makes sense now, rookie mistake haha for some reason I thought white was the ground, swapped the wires, green for ground and it works now! thanks for the help!!
    Miami,Fla.(305)
    808
    I did say green was ground...anyway, white is low beam , blue is high beam- so you know next time. (This is for the Hondas)
    Previously Owned:
    1981 ATC 185S
    1984 ATC 250R
    1981 ATC 250R
    1983 ATC 110
    TRIKELESS
    Nov 2013
    NB canada
    67
    yessir!! Ill remember for sure lol
