So i just received my clarke gas tank for my 85 250r. the problem is when i mounted the front mounts the rear mounts were off by about 1/2inch. i built shims for the front brackets to bring the tank backwards but this caused the front of the tank to be about two inches too high not allowing the rad shrouds to go on. Just reading skidoo99's post about that 86 frame and its mentioned that the front mounts are different between the two years. clarke says to switch the mounts from side to side but thats not going to do anything. Anyone else have this problem and have a solution or am i going to have to make mounts to match the OEM ones. thanks Sam.
