Don't go Chinese man, results vary but I think an oem carb should be fine with a good cleaning as long as it isn't physically damaged. Hunters problem is definitely electrical. The 200 are notorious for the screwy wiring.
"Roll on 3"
RIP Ol' Deuce
"Long Live the ATC"Building: ATCr125xRiding: ATC200sx"I am not a mechanic, mechanics get paid for this. I do it because I enjoy it."
Well, I just checked for spark. It has good spark. That's not the issue. I pulled the plug wire off and put a screwdriver in it. It sparked a good 3/16". Then, I pulled the plug and inserted it in the spark plug wire. I still had a 3/16" spark jump from the tang of the plug to a ground. It's not the spark. It's something else. At least I think. Now, I'm back to thinking it must be a fuel issue. Gee whiz. I'm gonna lose all of the hair I have left working on this thing. One thing about it though, I'm going to learn more about engines!
I just placed an order for a new carb. Will be here by Friday, maybe earlier. Now if I can just figure out how to install it. Hopefully that will fix it! If so, it will be a cheap fix!
I'm dying to get my carb in the mail. I really don't know if that will fix it but I'm sure hoping it will!
Well, I got the carb. The only problem is, I have no idea how to remove the old carb, much less put this one on! Are there any tutorials that I can watch on the internet to show how? I've searched but can't find any. Thanks!
Try this site:
oscarmayer.net/ATC/manuals/
There's probably a service manual on there that could help you out with step-by-step procedures for carb replacement.
when you checked spark did you check it right after it died or did you check it later on?
have you checked your spark advancer if it is damaged or broken it could make your bike die and not want to start.
it is the part under the cover that says CDI take that cover off and the gold ring which is the pick up. Then look at the part that looks like this http://www.dratv.com/277w.html. If it is damaged this could be you problem and it needs to be replaced. You can either buy the new one that is in my link or find a used one on ebay any advancer from any of the atc 200 series will work. I know it made things on my 200m screwy. Oh don't worry about ignorance we learn by asking questions I only know because it took me hours to find out what had gone wrong with my bike.
Well, I have some good news and some bad news. The good news is, I got the new carb put on. The bad news is, it's still doing the same thing. It fired right up when I hit the starter. It ran, albeit a little rough, but it ran. I did have to keep it about 1/4 choked and had the throttle held in a bit. I ran it like this for about 2 minutes. I then got on, put it in gear, made it all of about 2 feet, and it died. And now, again, it won't start. I checked the spark again then and it's still got good spark. I'm just about at a loss.
86125m I don't know where you're talking about that part being. If you could describe it a little better, I'd try to find it.
the cover that its under looks like this http://www.ebay.com/itm/1984-Honda-A...-/200930753310.
Well, I'll look at that tomorrow. I'm too frustrated to look at it anymore tonight. I know 3 things. I have great spark all the way through the plug, I have great compression, and I have fuel running at least through the carb. I'm gonna scratch my head on it some more tomorrow and then look at it when I get home from work.
