Originally Posted by
Devilsclaw
I had the same problem that drove me nuts for months, but I finally figured it out. Not saying that's what's wrong with yours but I can relay my experience.
Ethanol fuel was sloughing off superfine particles from the fuel system which were passing through the filter and reformulating in the carb and plugging the primary jet. Long story short, what fixed mine: cleaned out carb for the fifth time, added a second fuel filter, a 30 micron. Rolled up a tiny little cigar made of 0000 bronze wool and stuffed in the primary jet as a last ditch filter. I now use ONLY pure gasoline without ethanol, and drain carb bowl after every outing.
Also, there should be no "adjusting" of the carb. It should be set to 100% factory spec, and only adjust the idle speed as required. Of course this requires the mechanic to actually look up what the factory jetting, float height, and fuel level should be. Most grease monkeys don't want to have to do all that extra readin and stuff! (Assuming no engine or intake mods)
This is just my experience, but sounds a lot like what you are going through.
Best of luck!
