Results 1 to 12 of 12
Thread: New member for MN
    Nov 2014
    Zimmtown
    22
    New member for MN
    Hello,
    I'm a new member to the site, I've been reading on the site for the last month and a half getting new info about my 1984 ytm 225. This is the first trike I've ever owned and have got tons of great info about it. One thing I haven't been able to find is more info about the mikuni vm22 carb that's on it. My carb leaks a large amount of fuel if I don't turn the petcock to off, I'd really like a carb kit to rebuild but also am open to purchasing a new carb. Does anyone know where to purchase either? I've found a bunch of vm22 carbs on eBay but they look very different from my carb.
    Thanks in advance
    f76's Avatar
    f76 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2014
    South Dakota
    323
    If you don't find an entire carb rebuild kit, sounds like you really only need a new needle valve or need to adjust the float position. The reason your carb is dumping fuel unless you shut the petcock off is because your needle valve isn't sealing against the seat. This can be because the needle has a groove worn into it or the float position is incorrect.
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Nov 2014
    Zimmtown
    22
    Your correct the needle does have a groove worn in it but the second part about the float position I didn't know it was possible to change this can you explain further.
    Feb 2014
    Victoria,Australia
    878
    welcome to 3ww
    73 atc 70
    84 ytm 200ern
    79 atc 70
    ytm 225 dr
    atc 90
    80 atc 110
    klt 250A
    84 atc 200es
    85 atc 250es
    San Marcos Ca.
    704
    Hey welcome to the site.I would check the needle valve and the float and do a good cleaning. I had this problem last week on one of my trikes.After a good cleaning, she worked great.Good luck.
    YamaBoss's Avatar
    YamaBoss is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2014
    Minnesota
    251
    Welcome MN brother, I believe the reason you can't find a vm22 carb that looks like yours is because the 84 225 came stock with a vm24. I also had the same problem with mine when I first got it, it was the needle. I ended up buying a carb kit for a yfm250(89-91). The guy at the shop and I matched up the needle and the were the same. Also I believe a carb kit for a timberwolf 250 will work and will be cheaper.
    f76's Avatar
    Jun 2014
    South Dakota
    323
    I would replace the needle first before doing anything with the float. If the needle fixes the problem, leave the float as is and go ride!
    85 Kawasaki KLT 160
    85 Kawasaki KLT 110
    82 ATC 70
    2000 Scrambler 500
    Nov 2014
    Zimmtown
    22
    Quote Originally Posted by YamaBoss View Post
    The manual says its a vm22 1984 Yamaha ytm 225dxl.
    YamaBoss's Avatar
    Aug 2014
    Minnesota
    251
    Quote Originally Posted by YtmLp View Post
    I also have a 84 225DXL. What manual are you looking at?
    Also here http://www.3wheelerworld.com/oldsite...specpage.shtml
    Oct 2012
    WI
    499
    Welcome to 3ww, always good to see Minnesota members on here. Go MN!!
    1983 ATC 200x
    1982 ATC 250R X2
    1983 ATC 250R : Future build
    1985 ATC 250R : Main rider
    1985 ATC 363R Duner
    1985 ATC 250R X2 : Future build
    1986 ATC 250ES
    Nov 2014
    Zimmtown
    22
    Clymer manual says different but yours is a yamaha manual thanks I'll go with that.
    Maine
    464
    Welcome to the site
    Current Trikes
    2 1985 Honda 250sx
    1985 Big Red
    2 1983 YTM 200k's. 1 for parts.
    KLT 250 Prairie
    1982 Honda 185 - Waiting to be saved
    1985 125m Parts Machine
    Still on the hunt for a 1986 350x and 250r.
