My buddy dropped these off to me yesterday. He bought all 3 of them 3 years ago for $600. They have sat and he has done nothing with them. The hope is to get all 3 running and leave them at his cabin on 800 acres with fantastic trails threw out(20 miles south of Hayward, WI). Which I have access to whenever I want so the labor is well worth it and he is paying for the parts.
All 3 are complete there are a couple tubs of parts not in the pictures. All 3 gas tanks are clean as a whistle inside. 1 has a 200CC auto clutch motor with 90 PSI. The leak down tester shows 40% loss coming from the intake and exhaust valves. Should be a quick and easy fix. The other 2 have 200x motors 1 is disassembled with a bad big end rod bearing. The last motor has Zero PSI and 100% loss from the leak down tester. When I pulled the oil filter/drain plug a piece of what I think is piston skirt fell out. So I've got my work cut out for me but it will be fun. I will update with progress. 1 at a time I'm starting with the auto clutch X.
