bought this plow off a member a few years ago. Getting around to doing something with it. had to make some mounting brackets as it didnt come with any. stick welded them up with some 3/32 7018. Got it mounted but it doesnt lift high enough. ? for you guys with plows. Will shortening the chain remedy this or will extending the rear tabs on the plow be a better option(obviously alot more work). There is alot of slop on the cross brace/lift mech that is causing some lift loss. you can see by the pics how much it needs to come up. need to figure how to secure at pivot points, was thinking of welding a tab or pin on the back of the plow and just notching the angle iron brace on the frame and pinning it. Gonna need a bit of work, but seems worth fixing. It is a cool design how you can completely brake it down. tubing is heavy wall.
this is in the raised position.
