Thread: Reverse Bleed Rear Master Cylinder
    Feb 2003
    New York
    619
    So I am riding and no rear brakes. I loosened the nipple on caliper. I had the cover off the fill.... and I could not inject fluid into the line..... dont understand it worked perfect on the harley. Any advise Im all ears thanks
    ♠ 58 ♠
    Ride 3
    6,728
    Nipple clogged ? I bleed the stubborn ones at the caliper banjo bolt .
    Jan 2011
    Choctaw, OK
    2,755
    I bleed at the banjo too.
    Nov 2010
    Damascus, Maryland
    108
    Take the banjo bolt and the line on the top of the rear caliper off, fill the caliper with brake fluid through the banjo bolt hole...Reassemble line and bolt...Fill rear master cylinder with fluid , then start over and try to bleed them as you would normally bleed the brakes....Pump the rear brake pedal 10-15 times and hold the pedal down, crack open the bleeder valve and quickly close it....Keep an eye on the fluid level , don't let it go empty in the bleeding process...GOOD LUCK...
    Mexico
    9,012
    Quote Originally Posted by sweetip2000 View Post
    Ran into that the other day, front brake. The issue was the lever adjustment. If its too far in (tight) the fluid is blocked from going into the reservoir when you try and push it. I've seen this cause brakes to lock up when they get hot too.
    It sucks to get old
    Feb 2003
    New York
    619
    yeah I was able to blow through the nipple so it was ok. I did a regular bleed and it worked out ok. Just wanted to use my horse syringe again. I have a rubber line at the end of the syringe and it just about fits over the nipple so Im thinkin maybe a bigger inside diameter for a hose on the syringe anyhoots thanks for the shout back.
    ♠ 58 ♠
    Ride 3
