Originally Posted by
RIDE-RED 250r
If that carb is like the OEM 200es carb, the idle mixture screw will be on the bottom of the carb housing between the slide and engine, facing downward. It's kind of tough to get to. But if thats what you have, it regulates fuel at idle, and therefore opening it will increase fuel, closing decreases fuel.
Most of the 4-strokes had fuel regulating idle mixture screws as opposed to 2-strokes which had air regulating idle mixture screws.. Easy way to tell: If the idle mix screw is between the throttle slide and engine, it regulates fuel. If between the slide and airbox, it regulates air. Not to be confused with idle speed screw.
