Time to lap the cylinder to the cases and clean up the cylinder. Starts with bolting the cases together and smearing the gasket surface up with compound. These cases were pretty scarred up. They appear to have been split numerous times by people with a large assortment of screwdrivers and steel s.
Stuffed rags into the case holes. They'll get cleaned again, but the less compound I need to get out the better. This not something you want trace amounts of anywhere in an engine.
Spent about an hour rotating the cylinder back and forth. Without the cases on a solid stand it's pretty awkward and there were lots of scuffs and scratches to get rid off. Interestingly the cases had a low spot on the corner where the cylinders are known to crack when a boost port is added. It didn't lap in for the first 30 minutes.
There were two scratches that wouldn't clean up due to their depth and both ran straight across the thinnest portion of the sealing surface.
The trick to fixing these is to carefully raise the surface with a punch. A couple taps on the inside edge of the cases and then a couple more right on the scratches, but not straight down, you need to tip the punch about 30 degrees towards the part you want to raise.
Now lap until the high sports are gone and voila, no more potential leak.
The cracked cylinder Neverlift gave me to practice porting on will be getting sleeved. The loop that the exhaust springs hook to had almost worn through. Rather than try to find someone to weld it I cleaned it up and placed a steel washer over the flat side of the loop and covered it with JB Weld. Now the springs will be pulling on the washer and not the aluminum.
