Very nice!!!
Very nice!!!
Are you going to build aluminum forks too? This 70 would look sweet with all that aluminum polished for the final product! Would need sun glasses just to look at it!
Mixing gas and haulin' ass
1984 ATC 70 x2
1985 ATC 250R-Ported/Polished, PWK 39mm, V-force 3's, Outerwears air box lid, FMF fatty with DG silencer, DWT wheels, LSR +4 axle, all black plastics
1985 ATC 250R-stock
Where did you get the gas cap & bung?
Thanks in advance.
I had the bung machined at work and eventually I'll have the cap made as well. I'm going to use the steel forks because I don't want to add suspension to this one. If I could make aluminum folks that looked like stock i would but I haven't figured out a way to get them to look right. If enough people want to see it polished I might have to try a polish it up a bit.
Follow on Instagram @buckit14
The whole reason I started this project was for me to learn about some of the machine we have that I don't normally use. The gas tank has been a fun project for me to learn on. I haven't done the machining on this project but hopefully I'll get back on the lathe and mill soon.
Here's a picture of the frame as it sits right now. I'm working on some gussets and the seat bracket right now. I don't think I mentioned before that the frame is extended about 2.5".
This is awesome you do fantastic work. Are you making templates so you can reproduce these frames? I'm sure some members on here would be interested in one if the price wasn't astronomical. In my head I'm picturing this polished then anodized gold with black plastic.
85 Tri-z Basket Case
Heeeyyyyy!! Glad to see you're here on the forum, man!! I've been meaning to ask you if you were because this is a killer build!
92 JP Outlaw hybrid (in progress)
87 LT265R (not much left stock)
too many bikes to count. too little time on hand.
I could make more of these frames but it would cost a lot of money and shipping wouldn't be cheap. I don't think enough people would pay just to save a few pounds on a 70. Anodized gold would look great but its not in the budget for me unfortunately.
Ya CJ I wanted to make sure I had a good start before bringing the project to 3ww.
Today I made the rear seat bracket. Tomorrow it should be welded to the frame along with the brace for inside the frame. It will be welded between the lower motor mounts and the bearing carrier.
Very nice!What will the finish be?
Everything made of aluminum will most likely be bare brushed aluminum. Anything steel will be painted black or grey and the fenders will be some red ones I have that I'll cut down since they're in rough shape. I'd like to get a blue set one day because I think it would look really good with the aluminum.
