Page 3 of 9 FirstFirst 1 2 3 4 5 ... LastLast
Results 31 to 45 of 133
Thread: aluminum ATC 70 build
  1. #31
    Mar 2013
    Central PA
    2,362
    Did you see the blue fiberglass fenders mr twisted made for ditch? It's a pretty cool style, didn't see any mounted yet though.
  2. #32
    Feb 2015
    Southern Ontario, Canada
    82
    No I haven't seen them. I'll have to do a search for them. I was thinking the electric blue fenders from Maier would look good but I'd rather get an 88cc kit. The budget on this is really tight and I'd rather have more power instead of nice fenders
    Follow on Instagram @buckit14
  3. #33
    You wanting to stay all Honda ? Poweroll makes stroker cranks for these or you could get the cylinder resleeved so you could bore it out to 90cc's
  4. #34
    Feb 2015
    82
    I was thinking I would just buy a basic cheap 88 kit and use the stock head. Like I said I'm on a tight budget. I want would like to keep as much Honda as I can but I need some extra power as cheap as possible.
  5. #35
    C.J is offline Just Too Addicted Arm chair racerJust too addicted
    Central, Louisiana
    639
    Powroll built "CRF50" would be the hot ticket but $$$$
    The 88 kit and a bit of port massaging will wake them up. Or talk to 1upfront, Hartley, he had a NASTY little 70 mill in his before he went to a PW50 engine
    92 JP Outlaw hybrid (in progress)
    87 LT265R (not much left stock)
    too many bikes to count. too little time on hand.
  6. #36
    You can use a ct or SL timing advance flywheel and mounting plate to gain some more power on the top end but it will have to be drilled to accept the recoil starter cage. Going to a bigger carb will help too. Leave the base gasket out that will help on the compression and get a piston for a bike they are higher compression. The SL heads if I remember right have a bigger intake valve than the atc's
  7. #37
    Feb 2015
    82
    Thanks for the tips I'll have to look into some of those options.
  8. #38
    Feb 2015
    82
    I got the seat brackets finished up and did some test fitting. The tank mounts are next then the tank can get finished.
    Attached Thumbnails Attached Thumbnails IMG_20150219_150401249.jpg   IMG_20150219_150308339.jpg
  9. #39
    Feb 2015
    82
    So I know I said I wasn't going to but I decided this build needed some aluminum forks since everything else will be aluminum.
  10. #40
    STL
    3,561
    beautiful work man!
  11. #41
    Apr 2010
    Cold Lake, Alberta, Canada
    537
    I am coming in late to this build, you are doing a fantastic job!!!
    I am how ever worried about the strength. The steel frames already bend and flex
    bad enough as is. I truly wonder if the aluminum will be up to the test.
    [B]
    Trikefest Alberta: 2017, 2020
    Trikefest 2015 A.K.A MUDFEST
    Coolpool: TURN!
  12. #42
    Toaster556's Avatar
    Toaster556 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2010
    Fraiser Valley, BC, Canada
    176
    Quote Originally Posted by big specht View Post
    +1 on the SL head. Other factory big valve heads are the CT70Hs, XL70s, CL70s and S65. DR Atv also sells a high compression 88 cc kit that would work extremely well with the big valve head, and a new version of the big valve head as well.
    That tank looks awesome, I wish I could work aluminum like that!
  13. #43
    Feb 2015
    82
    Thanks guys. I think the aluminum should hold up OK since I used material twice as thick or more than the steel frame. I know some people have had problems with their frames but my stock 70 has put up with everything I've thrown at it. Also if it does crack I'll just fix it and make it stronger.
  14. #44
    Feb 2015
    Halifax N.S
    25
    That looks great
  15. #45
    Apr 2014
    wisconsin
    146
    i found this build on instagram. currently have a atc 70/125 and is hands down my favorite trike of the bunch. im currently a 2nd year fabricator myself but wow man youve got some skills!
