Results 1 to 4 of 4
Thread: how to test atc 185s lightning coil
    Jan 2005
    Eastern PA
    95
    Hello everyone!!! I have been a member here for about 15 plus years and have always been a huge trike fan!! Recently the lights stopped working on my 1982 ATC 185s fully restored which I will post pics soon!!! I would like to know which is the easiest way to test the lightning coil?..... also if its bad I saw Ricky Stator makes one but I would need a regulator how do I hook that up if my coil is bad? Thank You everyone for your help.
    Honda Atc 185-toy/snow beast!
    KX250f-race bike
    Klx110-pit bike
    Jan 2005
    Eastern PA
    95
    I know the kill switch and light switch are separate would a fault light switch cause this? I checked all the wires they seem fine... the manual says to check the continuity between the yellow wore and a ground on frame is this correct if anyone can chime in ??? thanks everyone
    KX250f-race bike
    Klx110-pit bike
    Jan 2005
    Eastern PA
    95
    I also tested the continuity between the yellow wire and a ground on the frame and it was ok..... so to be sure I dunno if that works I took off the flywheel and tested continuity on the lightning coil by the 2 screws that it bolts onto the stator plate... does that work? I checked all wires my only question I guess will a faulty light switch cause no lights please help fellow trikers !!!! I wanna keep another one going since we are a dieing breed!!!!!!!!!!!!!!
    KX250f-race bike
    Klx110-pit bike
    Scootertrash's Avatar
    In the sticks
    4,628
