Page 1 of 6 1 2 3 ... LastLast
Results 1 to 15 of 81
Thread: Project 84 200x.
    frankydodo is offline At The Back Of The Pack Arm chair racerFirst time rider
    Aug 2014
    Quebec, Canada
    170
    Project 84 200x.
    Hey guys! So far i've had 4 three wheelers
    1- 1983 185s that i restored and then sold ( thread http://www.3wheelerworld.com/showthread.php?t=170955 here)
    2- 1984 200m ( damn great machine! )
    3- 1983 185s for sale
    Family picture!
    And the last one is this!
    A 1984 honda 200x. And my plan is to completely disasemble it and rebuilt it.
    So far im right here
    And alot of part ordered or to order
    New white Maier fender
    New brake master
    New brake hose
    New carburetor
    New front caliper
    New axle bearing
    New front tire
    New shifter
    New piston/ring/gasket wiseco
    New dg exhaust
    New tank decal 86-87
    New rear fender 85 decal
    New warning decal
    New tapered stem bearing
    New throttle cable
    New clutch lever/cable
    New seat cover
    New spark plug
    Oem headlight
    Oem headlight guard
    Oem gas tank red kote
    New 400ex hub ( wider )
    My inspiration came from this picture
    But mine will have
    Black frame, headlight, headlight guard, fork boots
    Black/red hand grips
    The 87 tank decal will have the HONDA in black instead of blue and the triangle in the A of ATC on the rear fender will be black instead of blue also
    Not my pic i do not own copyright for that!
    Ill keep you guys update!
    wisconsin
    146
    currently working on my 85 200x build. mine came with brand new white maier plastic for an 86-67 200x which fit but im going for all orignial. too bad you are in canada or id give you a decent deal on them.
    Aug 2014
    Quebec, Canada
    170
    Hey guys big update.
    last monday i bought another 200x for part for 350$. Its in really good shape compare to the first one so ill strip the new one and take best part of both atc to make the ultimate 200x haha :P
    Heres the new 84.
    and couple things i already bought
    fender brace
    front stainless braided brake hose
    rear master with integrated reservoir
    87 decal but mine will have the honda in black and the triangle in the A of ATC in black
    new front master
    front kx 100 caliper for my front caliper
    Ill will also buy a cr85 front caliper to act as a rear caliper on my x
    Does anyone know which rear brake line fits good on a 200x?
    I was surprise because i have alot of goodies with the new one
    supertrapp exhaust
    oem tool box (missing cover but ill try to make one)
    renthal handlebar
    good working not bent fork
    good rear shock
    chrome grab bar (maybe DG?)
    frank
    Aug 2014
    Quebec, Canada
    170
    I need some opinion guys.
    Rear and front fender will be white.
    The frame/headlight will be black
    And now the scoop
    White or black?
    If i choose white it will have the 87 decal on the tank
    If i choose black ill put the 85 honda wing sticker.
    The rear fender will probably have the 85 decal ( the best lookig in my opinion )
    So the tank? Black or white scoop?
    Dec 2014
    alberta canada
    34
    here's how mines goingClick image for larger version.
ID:	213325Click image for larger version.
    Dec 2014
    alberta canada
    34
    paint the motor a flat black with a wesco piston 10.25:1 Click image for larger version.
    Dec 2014
    alberta canada
    34
    got to here today Click image for larger version.
    Dec 2014
    alberta canada
    34
    going to go all black plastics Click image for larger version.
    Aug 2014
    Quebec, Canada
    170
    I just ordered my white maier fender set with super scoop!
    The frame will be sandblasted next week and paint in black also!
    Also bought the engine today!
    Its a 250cc lifan/loncin whatever chinese brand honda clone and best of all it has electric start !
    Also its the OHC version not the OHV
    The biggest deal is going to mess with the wiring but im not really afraid of that!
    With the exhaust and modified airbox with uni filter i hope it will top at least 22-24 hp.!
    Aug 2014
    South Louisiana
    1,915
    Quote Originally Posted by frankydodo View Post
    You may need to put a little more into the motor for it to push that kind of hp. That is a good start though. You will likely need to rejet the carb for it to run right which will also give it more power. What carb are you going to use?
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Slidell, LA
    4,737
    X2....unless that Loncin has some wicked bore/stroke that I am not familiar with, 22-24 hp is a bit high even with an exhaust and upgraded air filter
    Mar 2007
    Texas
    5,046
    The 250 with best carb and exhaust can give him about 15-16 hp unless he tears into it and does a lot of internal work.
    ________________
    https://www.mikesatvfix.com
    Aug 2014
    Quebec, Canada
    170
    A 30mm carb will be use and the guys at the shop i bought it said 19hp out of the box. I dont know if its true but the thing is it will be at least a little more powerful than a stock 200x.
    Aug 2014
    Quebec, Canada
    170
    I just saw the numbers for the pushrod version of the lifan 200cc and it says 16hp. I know its not whp but i tought that the 250cc ohc would have a little more than the 200 ohv...no?
    Aug 2014
    South Louisiana
    1,915
    Hey maybe so, only real way to tell will be on a dyno. What gearing are you running?
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
