The front tire is a hi run 16x6.5x8. I bought it at tractor supply, it was probably meant for small lawn and garden trailers. I bought the tire first then found a rim off eBay to fit it. I imagine it was off a small Chinese quad. If I were to do it again I would have used an 81r front hub because I hear you can get an 8" rim to fit that bolt pattern. Live and learn. To make this setup work ben cut the welds on the wheel mount with a lathe so he could center the wheel between the forks. I then had the center of the wheel cut out to the same size as the outide tabs on the wheel mount so the wheel would be held true (hubcentric instead of lugcentri). Lug holes were drilled, the wheel was bolted to the mount and then ben was able to center it. He also used a larger brake rotor (200x I think?) It is also using a first gen 250r fron axle which I still need to have cut down and threaded.
I'm having problems uploading pictures, I'll try again later
