So I bought this beauty a few weeks ago. seemed to run really good and ride fine. got it home and ed on it a bit in the woods and it developed a LOUD clunking from the bottom end. horribly loud. so loud i pushed it back, threw it in the truck, and went home. It didnt seem to be coming from the crank it seemed further back. I removed both clutches and found the primary was looooooose. The nut holding it on was finger tight. I measured, cleaned, torqued everything up and gave it a ride. same clunk. no bad sounds in neutral, rarely clunks in first, a little in second, horrible in 3rd+.
SOOOOOOOooo... sunday night I removed the swingarm expecting to find a bad U joint. U joint was fine. Grrrrrrrr. I sat there for probably 45 minutes looking at the rearend and the U joints before i actually spun the damn output/middle gear assembly a full turn. CLUNK. :O! Off with the cover! And here is what I found.
Crunchy... OK now that thats out of the way and I know the issue.... I have a few questions. Its obvious someone was in this engine before. The secondary clutch is brand new, all the screws (WHY use philips screw heads?!) are dorked up, and its "missing" all of the shims from the middle drive area. I think!?
yamaha lists 3 parts for these shims
24W-17537-30-00 SHIM, THRUST (0.2T)
24W-17537-50-00 SHIM, THRUST (0.4T)
24W-17537-40-00 SHIM, THRUST (0.3T)
Im also having problems navigating my manual regarding anything to do with the shims.
so.
shims? what? where? how to measure clearances and all????
gears! am i screwed to only using 225dx gears? or will others fit if i use my shaft and swap the gears around?
GRRR
