So I bought this a few years ago and it seemed to run fine. I never REALLY rode it, just about two minutes slowly putting around the parking lot before tearing it apart for various maintenances, and it hasn't been run since. Finally got back to it after a while, took off the exhaust and found a damaged piston.
When I took the piston out, there were NO pieces of the ring left! So now I'm thinking... do I have to split the case to find missing pieces or do you think they just blew out the exhaust? This may sound dumb, but would it do any harm to rinse out the case with gas or some solvent a few times by turning it upside down to dump it? (Engine is out)
Can anyone tell what may have happened to this one? I mean, I know it got hot but is there any tell tale sings of the cause? I have no way of knowing the premix ratio the guy was running. The reeds don't have the stoppers and I don't know if they're stock or what. The bike is pretty much stock otherwise.
BTW, anybody know what piston this is? Honda? I'm pretty sure it's 0.25 over, due to a marking on the remaining ring that says 25
