Surprisingly getting it done right is not much more than a normal rebuild from a specialist. Replacing some o-rings is. It a rebuild. That is a refresh. A rebuild replaces and mics parts for wear and replaces all those. It also revalves and resprings for rider's weight. All of which is important for it to work together correctly. One must understand ride technicial details before they can truely make the suspension work like it should.
________________
https://www.mikesatvfix.com
I can't remember the exact deal, but I believe the 86 200X spring fits and is softer than the 85 200X spring. Because I was heavier and someone sold or gave me an 85 200X spring. IDK how much you weigh but a custom shock is the way to go.
I will have an AXIS rear shock on the 350RX (Well, it's been ordered) with soft ride suspension, hi and low speed compression damping adjustments and a spring for my weight. They are not inexpensive
I'd gusset the frame and do something with the front downtube, the 83-85 200X's like to break there!!
"Roll on 3"
RIP Ol' Deuce
"Long Live the ATC"Building: ATCr125xRiding: ATC200sx"I am not a mechanic, mechanics get paid for this. I do it because I enjoy it."
________________
dc what is the benefit to having the extra reservoir on those? Those sure are purdy
I'm pretty sure the only problem with the shock i have now is my stomach. I'm keeping an eye on this, I've been wanting to do a little something to my 200x. Its been stock in the year since I've had it but I'm starting to want more from it.
Suicide Hill Survivor
The rides:
1981 ATC110
1982 ATC185
1983 ATC185s
1984 ATC200es
1985 ATC200x
When the going gets tough, the tough get sideways
Talk to onformula1. He can help mod it so it feels like a couch.
________________
If you used the 350X shock which is about 4" longer and is about a 1/2" bigger in diameter and stuffed it in there at the same angle you are fine.
Now the issues are-
Stuffing it in there correctly so it doesn't hit anything. They are much bigger.
Fitting a shock reservoir that is about twice the size in the stock mounts.
Trimming the larger 350X top shock eyelet down to size.
Trimming the swing arm pivot point because the 350X shock is narrower.
Buying a new rear spring because the 350X spring is much, much softer.
"Roll on 3"
RIP Ol' Deuce
That sounds awesome, definitely want to hear more on this subject.
Coonassenginuity- the use of makeshift technical knowledge stemming from the bayous of southern Louisiana. Most of this knowledge comes from staring at something for long periods of time. Other forms include trial & error, jerry rigging, and my personal favorite, shot in the dark.
"Roll on 3"
RIP Ol' Deuce
________________
I use OCD Engineering, of course I don't have much choice!
But It works for me.
^ looks good sir!
________________
