Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
Thread: 200X suspension modifications
  1. #31
    Surprise, AZ
    2,430
    Quote Originally Posted by RapidRick View Post
    Kind of already overcome those issues a while ago, 2011 I think (wasn't the first) and attached a 350x front end on for good measure. I liked it, because it fit my riding style and worked very well for me.
    Very nice I like it!
    The build we are doing is from- oscarmayer, 3 different trikes, 3 different MX bikes, a bit of aftermarket, Joseph Farrow's help, pictures & info and a little bit of me.
    All in a tidy little MX package, to bring a MX type trike to a quad track.
    Here is my inspiration, Thank You Mr. Farrow Click image for larger version.
Name:	joes pics phone 542.jpg
    Thank You oscarmayer for the 200X-MX idea before I remembered the trike in this picture.
    It has been done before, but this will be a bit different.
  2. #32
    Mar 2007
    Texas
    5,046
    totally sweet looking!
    ok hear is a teaser. ever wonder what it would be like to have the 350X complete suspension on a 200x? including rear swinger? We shall soon find out!!!!
    ________________
    https://www.mikesatvfix.com
  3. #33
    Surprise, AZ
    2,430
    Quote Originally Posted by oscarmayer View Post
    Do you think it will work?, Do you have a welder?
  4. #34
    Mar 2007
    Texas
    5,046
    what's a welder? Don't they have superglue these days? Come on man Duhh you superglue it on and it's good.. :P
    ________________
  5. #35
    Surprise, AZ
    2,430
    I don't like superglue I keep gluing myself to myself.
    JB weld it, if you can use JB weld are you a welder?
  6. #36
    Mar 2007
    Texas
    5,046
    well POOP!!! I have to get another 350X triple tree cause we used the stem out of it for the custom Baja setup LOL. oh well.. ebay time!!!
    ________________
  7. #37
    Manheim, PA
    5,760
    The best suspension mods I have done to a 200x is the following:
    83/84 250R triple tree (bore steering them to ID of 200x stem since 250R runs a smaller dia stem)
    Bolt 250R forks to it and gain 3" or so.
    everything else from a 200x bolts to it.
    83 250R rear shock almost bolts to the 200X, you need to machine a new shock bushing for the top. The lower bolts to the swinger linkage like the factory 200x shock. You will need a new linkage made that sits 1 hole dia lower so you keep the rake and trail the same of the bike.
    All this does it give you another 3 inches of travel in the rear. The bikes float like a dream them.
    350X rear shock has a very high spring rate of about 800+ lbs I think I remember. The 250R one is softer.
    This is the only way I would ride a 200x anymore. It is not a costly mody. I did my home works on this one years ago when I built one. All the information is in my HRE 200x thread if anyone needs to copy. Attached is the photos of the 83 R shock. you can not use the 84R shock is in an inch longer.
  8. #38
    Mar 2007
    Texas
    5,046
    ^ cool man! thanks for the info!
    ________________
