Results 1 to 15 of 30
Thread: Help with problem not running Yamaha 225 Trimoto
    Jan 2015
    Beausejour MB
    51
    Unhappy Help with problem not running Yamaha 225 Trimoto
    Hi my Yamaha 225 trimoto is not running it has baffled me for a while and is still baffling me. What it is is that it does not run on factory setting for carb if i adjust the setting quite a bit richer it might run but very rough and it surges very quickly . you do not even have to push the throttle much and it surges. I was wondering if perhaps it might be the valves but dont know. Because no adjusting on the carb helps at all. And carb cleaner if you have enough in the tank helps a little. A lawn mower i worked on wouldnt start till i cleaned the valves and carb and it had much the same symptoms. Please help !!!!!!!!!! the machine has been sitting around and every time iget it running and ride it it almost seems to get worse. I woould so like to drive it.
    Yamawheeler's Avatar
    Yamawheeler is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2014
    Regina, SK, Canada
    225
    New jets in carb? Check fuel cack could be plugged up like mine was. Do valves tick at all
    Jan 2015
    sudbury ontario
    38
    Download the manual from 3ww or google it.. take the valve covers off. Take the timing indicator cover off. Find pull it over til u find top dead center.. theres a line on the flywheel. Check if the valves move. if not spin the engine 360 degrees and check it again. Because its a four stroke. Once u found TDC u should have some movement or play. check adjustment with a feeler guage. If its off. Loosen the lock nut and adjust thr valve to the spec.. something like 0.12 or 0.08 for exhaust valve and 0.05 for intake...just an example i cant remember....if that doesnt do it. Its carb related or throttle cable
    Michigan UP
    1,005
    Cleaning the carb involves more than putting carb cleaner in your gas. Pull the carb apart and clean it. You have something plugged up inside the carb.
    Aug 2014
    South Louisiana
    1,915
    That is the issue, completely disassemble the carb and clean all of the jets and blow every hole out with compressed air.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
    Jan 2015
    Beausejour MB
    51
    Quote Originally Posted by Jmoozy27 View Post
    The carb is clean ive cleaned it many times do you think its an air leak? i dont want to dig into the engine very fast cause all that timing chain and all that stuuf is there do you think i should try maybe getting a carb rebuild kit? but i will clean the carb again with carb fluid
    Jan 2015
    Beausejour MB
    51
    Question
    Quote Originally Posted by 225 Trimoto View Post
    do you think the timing is out of wack? it might not be getting the fuel at the right time? or letting the exhaust out at the right time?
    Jan 2015
    Michigan
    43
    Im pretty new to all of to all of this myself but Ill try. Is it backfiring into the airbox? is the header pipe getting hot? If so and you've tried starting fluid around the intake and whatnot Id look into your valves. I just went through all of this with my 200k. Valves ended up being out of adjustment. Best of luck!
    Jan 2015
    Beausejour MB
    51
    itts not backfiring in the air box but it backfires something horrible out of the exhaust the whole engine gets hot very quickly though its probably either the timing or valves or carberatur
    Jan 2015
    Michigan
    43
    Have you made any progress?
    Jan 2015
    Beausejour MB
    51
    Quote Originally Posted by Mi-lptroll View Post
    I havent had enough time
    Jan 2015
    Michigan
    43
    Such is life my friend. Well keep us posted when you do get to it!
    Jan 2015
    Beausejour MB
    51
    Question
    does it matter what type of gas i use? like should i use premium, regular,or purple farm gas in my ATC?
    Jan 2015
    Michigan
    43
    I would stick to regular unleaded [emoji14] . I did see an Atc 250r that runs on alcohol on Craigslist the other day though... >
    Sent from my SM-G900V using Tapatalk
    Jan 2015
    Beausejour MB
    51
    Question
    I changed some parts in the carburetor and now it runs very rough blowing black and white smoke I still have not checked the valves and I ran it for like 5 seconds and it got very hot and overheated in just that very short timeand I think its running lean but I would still like to have some advice on what to do exactly I'm not sure what it isplease help I want to get this machine running....!?.?!!!???
