Page 2 of 2 FirstFirst 1 2
Results 16 to 30 of 30
Thread: Help with problem not running Yamaha 225 Trimoto
    Feb 2015
    Catawissa, Missouri, USA
    138
    Firstly, try readjusting the carb, if not, it may be a timing issue. The rough running may be an indicator of the latter.
    By "running rough" does it still backfire a lot? That's one question to ask for the potential timing issue
    Never forget the past , but dont dwell on it.
    My toys
    Trike:
    1983 Honda Atc 185s (update: frame painted!)
    1986 honda Atc 125m (sold)
    Non - trike
    1968 Lomart Cheeftah Mini bike (3 hp Tecumseh)
    1968 wheel horse charger automatic ( modded)
    1981 Dodge Power Ram (driver)
    1981 Imperial (project car)
    Follow me on my blog! (Yes, its about trikes!) https://www.tumblr.com/blog/atctriangleofdeath
    Jan 2015
    Beausejour MB
    51
    Question
    Quote Originally Posted by Degoragon View Post
    it idles good its also gutless and surges if u put the throttle down hard or hold it halfway it seems to be running leam lean isnt that a symptom of surging?
    Yamawheeler's Avatar
    Yamawheeler is offline At The Back Of The Pack Arm chair racerFirst time rider
    Nov 2014
    Regina, SK, Canada
    225
    What did you all change in you carb?
    Jan 2015
    Beausejour MB
    51
    Question
    Quote Originally Posted by Yamawheeler View Post
    i changed the needle and seat for float and needle on top and o ring on main jet
    Nov 2014
    Regina, SK, Canada
    225
    Where did you out main jet clip could be to high or to low.
    Jan 2015
    Beausejour MB
    51
    I set it halfway to begin with but rais er d it one notch it runs better now it doesn't backfire now
    Jan 2015
    Beausejour MB
    51
    today I started on it up and it ran good l drove up a steep hill and then went for a drive down the road and it ran perfectly until I hit and I had lots of power until I hit washboard and then it got back to surging again so I'm Wonder ing if there is something in the gas tank
    Jan 2015
    Beausejour MB
    51
    Question
    I think that it is something to do with fuel valve cock it has probably has something in it and it is cause he had to move or something and it will the junk will settle in and it will Let the gas through and then it will pick up the junk and block it again
    glendive, montana
    1,822
    you were definitely running a lean condition, check your intake boot going from the carb to the motor by spraying it with starting fluid if it idles high from it the boot is cracked or the o-rings are shot. Also what is the main jet size, because it may be the wrong jet people have been known to put the chinese carbs on there, and they are known to have the wrong jets in them. you should be running a 112.5 main jet, and a #20 pilot jet. On your idle air mix it should go rubber o-ring washer spring into the carb and the screw should be 1 7/8 to 2 turns out from seating. I would still check the tank and petcock out for debris as well but double check your carb and intake. Make sure your air filter is oiled as well those machines use a wet air filter element, unless other wise noted because the jetting changes if it is used dry. These machines were also designed to run on 85 octane, however running higher octane wont hurt it as higher octane fuel runs cooler. you should also be running a ngk D7ea spark plug for the right spark temp. is your spark plug black and sooty or white, does it have oily residue on it?
    glendive, montana
    1,822
    you can also tell if you have a chinese carb if it has a lever on the carb for choke instead of using a cable going up to the dash with a lever.
    Jan 2015
    Beausejour MB
    51
    Lightbulb
    Quote Originally Posted by muthey View Post
    well the carb is a genuine yamaha carb as for the boot where do u spray starting fluid on the outside or the inside im running regular gas and it runs better than with dyed gas it does not have a OEM filter but it has a filter but im gonna clean the petcock and see how it works then
    glendive, montana
    1,822
    You spray on the outside all around the boot. Also always run regular gasoline, these weren't designed to run anything else. The non OEM airfilter can be causing the lean condition as well stock jetting is for an oiled OEM filter that draws air through the frame. I like to use Carb cleaner because it makes the motor die out insted of starting fluid which causes it to surge higher.
    Jan 2015
    Beausejour MB
    51
    Arrow
    i tried that but there is no leaks there is no gasket between the carb and the boot connecting it to the engine so im gonna get a gasket also when it gets hot it does not run as good as when its codl or just warming up but it idles perfectly!!!
    glendive, montana
    1,822
    there is an o-ring between the intake and the cylinder head, so if that is good you don't need a gasket, run it till it starts acting funny then shut it off and check the spark on the spark plug it may be your cdi is failing
  15. #30
    Jan 2015
    Beausejour MB
    51
    k thanks ill try it i have replaced the o ring between the carberatur and the intake manifold ill check between the intake manifold and the cylinder head see if that o ring is not good
