Tore open the engine today hoping to be the first in, but, somebody else beat me to it.
and sleeved the cylinder! Typical Mexican rebuild;
"O dios mio, whatever shall I do with this slightly aluminum smeared nikasil cylinder? Clean it with acid??? Hell no! Lets bore out the greatest metallurgical invention of the century and stuff an archaic cast sleeve in here!" Followed by;
"And let's not match the sleeve with old holes, or even the chamfer the ports!"
Wonderful. Fortunately the tools I made up to work on my Tri-Z cylinder fit very nicely in the 72mm larger hole. There is one messed up area I'll have to leave as is, but the rest will clean up with a few hours of work. In other good news they didn't gap the rings properly, so they are better than new (too small), just need to be gapped and the piston needs to be prepped, it's like new as well. Its a Wiseco and weighs a fair bit less than the Wossner I had kicking around.
The con rod seemed a little loose, so I split the cases and while I can see someone was in before and managed to score the crank seal surfaces of the cases the innards are mint. The clutch basket doesn't even have dimples! I have a spare crank with a fresh rod on it, so that will go in. Looks like there may have been a crank seal leak on the wet side as well.
The "Don" that put the thing together set the cylinder up.010" too high (KTM uses multiple base gasket thickness to get the piston head flush with the top of the cylinder) and retarded the ignition timing, so between the lack of compression, partially blocked ports and a spark plug I've never heard of you'd think it might run like crap, but not as bad as it was. No, that seems to have been caused by a .050' gap on the reeds when "closed". They will seal when sucked on, but in a relaxed state the gap is huge. I'm thinking this has to be the cause of the low reves. I should be able to get the engine together this weekend, but there's a locking clip missing from the power valve, so that will require a week or two to get, but it can be added in the frame if I get that far.
This is supposed to be the "spare" bike, but I'm getting some ideas for it...
