looks like a 83 185s-except for the tank and seat.
Previously Owned:
1985 ATC 250R (261cc)- 38MM PWK QV/AS, VFORCE3, RPM TIMING ADV., FULL DG EXH, CLARKE WHITE TANK, DOUGLAS RED LABELS, PRM NERF BARS, + ALUM. PARTS
1983 ATC 185S (186cc)- HI COMP., BASSANI HEADER, REAR DISC BRAKE CONV., '86 200X HUBS, ALUM. RIMS, DIRT DEVILS
1982 ATC 185S (224cc)- PK WELD-ON KIT, PK CLAMPS, PK EXHAUST, SL90 SHOCKS, OIL COOLER, PCCC RIMS
1981 ATC 185S
1984 ATC 250R
1981 ATC 250R
1983 ATC 110
1969 HONDA MINI TRAIL 50
TRIKELESS
I take that back-I just noticed how the rear of the frame goes straight out.-unlike the 185s. it has the rubber footpegs & front shocks though. might just be a mutt?lol
Previously Owned:
1981 ATC 185S
1984 ATC 250R
1981 ATC 250R
1983 ATC 110
TRIKELESS
i know it is a 200 but i need to know if it is a 86 or 83 200s
Previously Owned:
1981 ATC 185S
1984 ATC 250R
1981 ATC 250R
1983 ATC 110
TRIKELESS
thanks tho
I think it is a 83 185s frame which was the only 185s to have front shocks and a 200 motor which is a direct bolt in, and then they could use the later years seat on it as all previous years of 185s and anything before 84 on the 200 was a 2 piece fender and a different type of seat.
get the frame vin number to be 100% sure.
