New Product Listed: 45 Watt LED Head Light for 200ES and 84-85 200M
New 45 watt LED headlight with bright and dim. Connector has been replaced with Japanese connectors for correct fitment.
Light output: 3060 Lumans
Amp Draw: 3.75A /12V (45w)
Operating Voltage: 9-30V DC
Waterproof Rating: IP67
Size: 170 mm x 105mm x 80mm (L x W x H)
Material: Die-cast aluminum
Beam Type: Spot Beam
Life Span: 30,000 Hours
Working temperature: -40~85°c
Color Temperature: 5500K (Cool White)
Fits the following machines:
1982-1983 ATC200E*
1984 ATC200ES Big Red
1984-1985 ATC200M
*If headlight rim is used from a 84 200ES or 84-85 200M part number 33101-VM3-003 and spring holder part number 33109-440-931
More...
//ArrowChat Integreation Code
