Ya I totally understand. Been down that road many times and it does add up very quickly.
Got the rear wheels off, breaking down the front end for a full rebuild and removed the exhaust. Thats about it for today. Might have parts in tomorrow and should have the carb rebuild kit as well.
Nice. I just replaced the fork seals and changed the fluid in mine. I found one was bent pretty good.
I hope to give mine a deep cleaning and rebuild worn parts as well.
Ya I'd say that's just a little bent. Forks are readily available. The upper tubes are the same for both sides.
Dang that sucks!
Yeah doing these forks are going to be a breeze compared to the inverted Showas on my XR650L.
Oh found out that other motor I scored is locked up. Carb is seized as well. I think they left it outside. Bummer. Either way Ill toss it in storage until I decide to putz with it.
On the motor, remove the spark plug and shoot in a 50/50 mix of acetone and ATF. Let it soak.
Nertz I was going to toss deep creep in there before I took it to storage. I just got back. Its in a climate controlled room so its not going to get any worse at least.
HAHAHA, Identified!!!! A Frank Burns fan.. I thought I was the only one who says nertz
Gin machine and golfing all day!
Sent from my Nexus 5 using Tapatalk
“The world is a book, and those who don't travel read but one page.”
― Augustine of Hippo
My 1985 250SX Resurrection thread
Current Stock
1985 Honda 250SX
1988 Honda Fourtrax 300
2008 Honda XR650L
2003 Suzuki DR200SE (wifes)
MOTOVIKING
PMA4X4
Bringing the heat shield into the 21st Century! I used DEI Thermal tape I had laying around.
Cleaning up the exhaust system. I used a scotchbrite pad and some degreaser and scrubbed 30 years of gunk off. I have had great luck with VHT Flame header paint (1500*) for a base coat than the VHT gloss black engine enamel (500*) for a final coat on top.
Current Stock
1985 Honda 250SX
2008 Honda XR650L
MOTOVIKING
PMA4X4
Looks good. Nice attention to detail.
Pile-O-Parts!
The tires came dang near vacuum sealed compressed so I had to let them sit in the AZ sun for a bit for them to get back to their natural shape.
New ITP wheels all around
9x9 3x6 rears
10x5 2x3 front
I got them mounted and I am starting to think I screwed up on the size. the wheels are 9" wide (stock 200x/350x wheels) and the tires are 22x10-9. The tire itself says for 8" wide wheel. I am worried if I may roll them off the bead. I dunno what do you guys think?
Current Stock
1985 Honda 250SX
2008 Honda XR650L
MOTOVIKING
PMA4X4
I hate it when they compress the tires like that. A bead blaster fixes that but I don't have a bead blaster so I have had to resort to more manual means. Don't worry about the wheels, they will be fine.
