Looks great man.
Thanks. I had a blast building it back to where it is now. I wish I had done it sooner
Sent from my SAMSUNG-SM-N910A using Tapatalk
Did you use a plastic renew product on the fenders?
No I used a heat gun to bring the color back to the surface ( took about 6 hours) you dont want to get it liquid hot just hot enough to bring the color back and then scrub it with a 70 30 mix of paint thinner and boiled linseed oil. And it has to be boiled linseed oil or it will become a sticky nasty mess.
That is amazing what you did with the fenders. You need to describe your process in further detail. I am shocked!
What you did with those plastics is really impressive...wow. Surely there will be more interest in the process. The 350X looks fun too !
86 T3
84 T3
86 KX250
Ok I I will post a step by step tomorrow
Yes please those plastics look amazing.
Suicide Hill Survivor
The rides:
1981 ATC110
1982 ATC185
1983 ATC185s
1984 ATC200es
1985 ATC200x
When the going gets tough, the tough get sideways
Take heat gun on high and go back and forth over the fender in a straight line. Till just the top layer is pliable not liquid but loose and then cool it quick I use water and repeat until bright. As long as the color one the bottom is not faded it will pull it back to the top.
Does it only work on Maier? I see you replaced the front with oe,did you use the same process on the OE front? She sure was a rough start!
Yea. I put a lot of work into it. It should work on both. But sometimes you have to repeat the process a few times to pull the color to the surface
Looks good man
[/SIGPIC]
85 350x
83 200x-sold
×2 85 200x-sold
06 kx250f-sold
86 tecate-sold
86 tri z powervalved
85 BIG red
18 rmz250
87 lt80
19 ttr110
Very nice!
Nice work. Saved a lot of $$ too.
Wonder if it works on green plastic tanks?
Sent from my Z998 using Tapatalk
