Page 1 of 8 1 2 3 ... LastLast
Results 1 to 15 of 113
Thread: Built from scratch: 250R
    Aug 2015
    Germany, Bavaria
    98
    Hello Guys,
    after a few requests Loizl forced me to reactivate my old 3WW account, to show you my 250R project, wich was built in parallel to his Tecate 125.
    Link to the Tecate 125 Threat:
    http://www.3wheelerworld.com/showthr...ght=Tecate+125
    I always wanted a badass two stroke trike like the ATC250R, but they are hard to find and to expensive over here in europe. So i desided to built my own.
    The design of the trike began during the abroad year in england of my engineering studies. I bought a cheap Honda CR250 engine on ebay uk in great conditon as you can see.
ID:	220387Click image for larger version.
ID:	220388Click image for larger version.
ID:	220389Click image for larger version.
ID:	220390Click image for larger version.
    Cold Lake, Alberta, Canada
    3,019
    Is your intent to buy it piece by piece then? I seen a post where someone did just that and it was somewhere around 2/3rds more money than buying one and starting from there. I applaud your efforts and can understand your issues sourcing parts in Europe. Good luck!
    Trikes
    1970/71 US 90 (Aquarius Blue)
    1972/73 US 90 Green
    1982 ATC 70
    1983 ATC 70 (Ladybug)
    1973 ATC 70
    TF 2015
    Other
    1983 Honda Z50
    Aug 2015
    Germany, Bavaria
    98
    The project is already finished and the total costs were far below 1000€.
    I will now post part by part the complete manifacturing... It just takes some time to upload all the pics and write a few words to every step.
    Aug 2015
    Germany, Bavaria
    98
    After a bus ride across europe the engine arrived save in my workshop:
ID:	220407Click image for larger version.
ID:	220408Click image for larger version.
    Aug 2015
    Germany, Bavaria
    98
    The engine case was cracked by the pre owner, so it was necessary to TIG weld the cracks and after the paintjob it looked like that:
ID:	220411Click image for larger version.
    Aug 2015
    Germany, Bavaria
    98
    The clutch cover and the generator cover was to damaged to weld it and therefore new covers were cnc milled:
ID:	220413Click image for larger version.
ID:	220414Click image for larger version.
ID:	220415Click image for larger version.
ID:	220416Click image for larger version.
ID:	220417Click image for larger version.
ID:	220418Click image for larger version.
ID:	220419Click image for larger version.
    Aug 2015
    Germany, Bavaria
    98
    A jig was weld around a tecate frame to get the position of all the holes and tubes:
ID:	220429Click image for larger version.
ID:	220421Click image for larger version.
ID:	220422Click image for larger version.
ID:	220423Click image for larger version.
    Here is the finished frame compared to a tecate 3 frame:
    Aug 2015
    Germany, Bavaria
    98
    First testfit of the engine into the frame:
ID:	220426Click image for larger version.
ID:	220427Click image for larger version.
    Aug 2015
    Germany, Bavaria
    98
    I had a CR250 fork laying around from another project which was combined with a 250R tripple clamp from ebay.
    The tank is from a Honda MTX 125 that i cannibalized a few years before:
ID:	220473Click image for larger version.
    Here are some pics of the original magnesium clutchcover that was burned
ID:	220475Click image for larger version.
    Aug 2015
    Germany, Bavaria
    98
    Some picture of the plasma cutted engine mounts and of the engine fitting in which was a PITA:
ID:	220434Click image for larger version.
ID:	220435Click image for larger version.
    Design of the aluminum subframe...
ID:	220437Click image for larger version.
    Aug 2015
    Germany, Bavaria
    98
    Safety first, therefore i bought nerfbars for a yamaha blaster that fitted on my frame with some minor cutting and welding action...
    A red fender of a chinese quad won on ebay and the 4 snows of my former built the "Mocate 250" completed the first mock up:
ID:	220479Click image for larger version.
    Later this week i will go on with my report but for the moment this should be enough... see you
    phantomtracer's Avatar
    phantomtracer is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Pa
    392
    Wow! Nice work!
    When you said from scratch you weren't kidding.
    Surprise, AZ
    2,428
    What is the paint on the power valve covers? It's a interesting color/look.
    Nice trike, Thank You
    Apr 2010
    Germany
    143
    The powervalve covers were anodized and were expected to be red but honda used a lot of different alloys for different parts so they came out some kind of Bordeaux color.
    87_T3________83_500x_______86_T3_______86_350x____ Tecate60_____88_T4
    By loizlone at 2011-08-20
    Surprise, AZ
    2,428
    Quote Originally Posted by loizl View Post
    Thank You, with casted aluminum it's tough to anodize any color other than clear or black.
    I like them they look like a exotic works coating.
