So I need to remove the flywheel on my 185s, and the threads that you usually screw the puller into are destroyed. How to I go about removing it now? Maybe using a puller hooked on to the recoil start basket? Also the impact sockets dont fit in the hole to remove the flywheel nut, so what is the best way to remove it using a ratchet or johnson bar?
Thanks
on a puller that was held on by those 2 bolts? I might be able to make something up then that would work with a slide
