Results 1 to 11 of 11
Thread: '84 200s Rear Brakes - Video
    Sep 2015
    Worcester, MA
    34
    Question '84 200s Rear Brakes - Video
    Hi Guys-
    What am I missing here?
    Thanks
    https://youtu.be/LqkSJUxcuPA
    Sep 2015
    Worcester, MA
    34
    The drum seems to be in really good shape to be honest...
    I will get a better picture/video when I get home.
    What do you mean by measure the I.D.?
    BigRedGrizzly's Avatar
    BigRedGrizzly is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    May 2015
    Jersey
    296
    https://vimeo.com/138686140
    Simple fix. All you need to do is take the adjuster arm off, it's splined. Much like the shifter. Rotate the adjuster backwards a bit. When you re-install the adjuster arm make sure it goes all the way back in. There may be a spring that has to be re-installed as well to hold the adjuster arm backwards. On my 250SX there was also a ring with a point on it. That has to be set in properly or it won't let the adjuster arm return to the proper position on the splined shaft. That's it. Easy.
    May 2015
    Jersey
    296
    This illustration may prove to be more helpful.
    Sep 2015
    Worcester, MA
    34
    You kick ass dude!
    I will give this a try this weekend when its not so damn hot here in Mass!
    Again, THANKS SO MUCH!
    Sep 2015
    Worcester, MA
    34
    Ok I couldn't help myself! I had to tackle this tonight!!!
    Question, what are the two things I took note of in the picture and do they need to be hooked up?
    Thanks
    May 2015
    Jersey
    296
    No problem man. Glad to help. I have received so much great guidance from guys on here. We are happy to help solve problems.
    I think it may be a breather tube. I'm traveling to Boston tomorrow for work. Avon, MA to be exact.
    See this pic. I think the tube is visible.
    May 2015
    Jersey
    296
    You can download the service manual for free from here.
    http://www.oscarmayer.net/atc/manuals/
    Sep 2015
    Worcester, MA
    34
    Avon is about an hour away from me says google maps! Whats the purpose of the breather tube?
    Thanks man
    May 2015
    Jersey
    296
    I honestly don't know. I could be entirely incorrect. I wasn't able to find a good description of it in my service manual.
    Aug 2014
    South Louisiana
    1,915
    It's there for different reasons but mainly just for expansion purposes and to reduce moisture build up. Just so the brakes can breathe when hot.
    "Roll on 3"
    RIP Ol' Deuce
    "Long Live the ATC"
    Building: ATCr125x
    Riding: ATC200sx
