Results 1 to 8 of 8
Thread: Will this fit on a 86 250r
    davham's Avatar
    davham is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    211
    Have a look and tell me what you think, I need a new axle. I know the rear ends are not the same and wonder if this will work or is there a problem with the hub location.
    http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=2455624476&category=43 974
    '85-1/2 Mint Tri-Z now scattered across the U.S.
    '86 250R frame off with as many new parst as possible
    '85 250R daily driver
    '85 250R needs an engine-got one?
    Mar 2003
    Barnesville,Ohio
    2,298
    I dont think it will b/c on rocky mountain 86 250R's are listed with trxs and 85 is by itself.
    1985 Honda 350X - a lot of performance stuff, everything but a cam, hope to get one soon
    1984 Honda 200ES
    198? Yamaha YT60 Tri-Zinger
    TrikeFest '04 & '07 Survivor
    CENTRAL NY
    1,709
    the 85 and 86 sprocket mounts on the opposite side of the hub. you would have to change the hub or use a 85 carrier, swinger, and calipor mount
    1985 250R Selveys port job and pipe
    1985 70 piped for lil'freaks
    2001 TRX90
    ATC 90+250R+BEER= Drag Bike
    1984 ATC70 Pit bike
    1984 110 for sale
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,246
    IT WILL WORK IN ANY YEAR TRX OR ATC,,,, i have a 88 trx 250r axle in my 85 carrier fits like it was made for it,,,, the sprocket is different but it still lines up ,,,, the advantage is the trx axle is noticeablly larger in diameter out at the ends by the splines ,,,
    CENTRAL NY
    1,709
    Quote Originally Posted by KASEY
    now now... no need for yelling.............. he didnt ask if a 86 and up will fit an 85.........the 86 carrier sticks out past the swinger futher than the 85 carrier so the sprocket hits it, BECAUSE of the different sprocket mounting............. I tried it on my 86 TRX
    2001 TRX90
    1984 ATC70 Pit bike
    1984 110 for sale
    Apr 2003
    546
    i know for a fact that the bearing carrier for an 85 is EXCLUSIVE FOR 85......i also know that the axles are different for 85 and 86....what the difference is i am not sure.....are you as confused now as i am?....good luck
    1985 ATC 250R
    2006 TRX450ER
    RIDE RED...IS THERE ANYTHING ELSE??????????
    davham's Avatar
    Jul 2003
    211
    OK thanks, guess I wount be bidding. Are the Dura-Blue heavy duty axles good and strong.
    Rittman, Ohio
    6,276
    Ive got a stock one from an 86TRX250R on ebay, unless your trying to find an aftermarket one. The aftermarket ones are stronger, but they tend to break instead of bending. Ive never bent a stock one, myself.
