Thread: New Product Listed: 45 Watt LED Head Light for 200ES and 84-85 200M
    Billy Golightly's Avatar
    Live Oak, FL
    15,066
    New 45 watt LED headlight with wiring for bright and dim. Connector has been replaced with Japanese connectors for correct fitment.
    The wire colors are as follows:
    Black: Ground
    Red: Bright (All 15 LEDs on)
    Blue: Dim (6 LEDs on)
    Light output: 3060 Lumans
    Amp Draw: 3.75A /12V (45w)
    Operating Voltage: 9-30V DC
    Waterproof Rating: IP67
    Size: 170 mm x 105mm x 80mm (L x W x H)
    Material: Die-cast aluminum
    Beam Type: Spot Beam
    Life Span: 30,000 Hours
    Working temperature: -40~85°c
    Color Temperature: 5500K (Cool White)
    Fits the following machines:
    1982-1983 ATC200E*
    1984 ATC200ES Big Red
    1984-1985 ATC200M
    *If headlight rim is used from a 84 200ES or 84-85 200M part number 33101-VM3-003 and spring holder part number 33109-440-931
    *NOTE* The spring holder will have to be slightly bent to fit the LED light in the OEM housing.
    Electrical Note:
    If you plan to use this in a machine not listed, please make sure the light is powered with a regulated 12v source. All machines that have a battery will have the required regulator.
    More...
    Sep 2015
    Western most part of N.C.
    53
    Is anyone running this light? How is it?
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Wow sounds too good to be true!!!
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Crazyktmmatt is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2014
    Idaho
    237
    I bought a set of these for my snowplow - seem pretty bright. Next Im gonna figure out how to put on in the 250es. I already did a 12" 120w led light bar, so im not sure how much more light I need....
    200x - I think I have 7 of em?
    10 70's
    3 350x's
    Tri Z
    225
    kxt
    and the 90 110 125m that I need to get rid of.
    YT175 with rear suspension sold
    200es- SOLD !!!!!!
