Results 1 to 3 of 3
Thread: Suzuki LT-4WD - Carb Issues and Dim lights above idle.
    Jun 2003
    South of Rochester, NY
    3,471
    I have been given a second LT-4WD. Machine has carb issues with the idle circuit (plugged internally), just like mine. Has anyone replaced the poorly designed original with a new/different carb? It came with a Mikuni VM24SS carb....(off memory...)
    Also, this one the dash and HL's are as bright as mine are when it's low RPM/idling, but if you rev up the motor, they dim out to nothing. Any ideas? Regulator or stator issues I assume?
    Also, sometimes the shifter doesn't return down, and it stays between gears. Is there a spring that is suppose to bring the shifter back to the "middle" position?
    That is all...
    Hondaline Hartman
    '86 ATC350X - 'Go-Go Girl'
    '85 ATC70 - All Original
    '83 Suzuki ALT125 - Pieces
    Oct 2008
    NB, Canada
    852
    On your lighting issue, how's your battery? Most bikes act just like that if you're trying to run them with a bad or no battery.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    Jun 2003
    3,471
    Yeah....put in a new battery and lights are now good.... And battery voltage on high rev is about 14V.
