Results 16 to 30 of 51
Thread: Buckit14's 200x rebuild
    Feb 2015
    Southern Ontario, Canada
    82
    I removed one of the factory gussets and added a much stronger one. For the down tube gusset I copied an article from an old 3 wheeling magazine article. It should be strong enough for the riding I'll be doing.
    Attached Thumbnails Attached Thumbnails IMG_20151208_072039649.jpg   IMG_20151217_150203049.jpg   IMG_20151217_150057918.jpg
    Follow on Instagram @buckit14
    Surprise, AZ
    2,430
    Nice work, nice welds, nice gussets you are talented!
    Mar 2007
    Texas
    5,046
    I happen to have a complete 350X front and rear shock setup with the Gold valves ready to run. New springs and everything. I am going to polish the bottom tubes and install new boots and them put them up for sale. I paid $780 for them to be rebuilt and that does not include polishing or the boots. I would take $600 for the set of 3 (front and rear) or $500 for the front forks shipped.
    BTW nice Fab work and repairs! keep up the great work!!! I would on the front down tube, add a support from big the tube to the 2 smaller ones.
    ________________
    https://www.mikesatvfix.com
    Feb 2015
    82
    Thanks for the offer. That sounds like a great deal but unfortunately I don't have the budget for that. Too many projects and not enough money. I'm going to have to settle for freshened up stock forks for now.
    Feb 2015
    82
    The grab bar is done. It's nothing special but it'll do the job.
    Quote Originally Posted by buckit14 View Post
    Those welds are spot on.
    Is that a TIG. or a MIG??
    Jan 2014
    La
    1,062
    If you are looking for cheap tires it doesn't get cheaper than these https://www.rockymountainatvmc.com/p...nobby-ATV-Tire. Really there are no cheap tires trust me I know.
    Manheim, PA
    5,759
    those round tires will offer no performace. you want flat 20's on the rear or smaller.
    Oct 2013
    Wherever I May Roam
    3,757
    Good used tires on wheels are the best value. Lots of modern take offs out there. Get darn near whatever wheels and tires you want then get the hubs to match. Usually for about 1/3 the cost of new, and new tires don't slide well at all.
    1979atc's Avatar
    1979atc is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jun 2015
    NW Ohio
    213
    Looks to be tig to me, and the welds are really nice.
    Feb 2015
    82
    Thanks guys. Yes everything has been tig welded.
    Feb 2015
    82
    I added another gusset to the frame at the bottom of the down tube. Also my bearings and seals came in and I have some questions. What fork oil should I be using? Since I'll be using stock forks for now is there anything I can do to make them work better?
    Attached Thumbnails Attached Thumbnails IMG_20160107_205213062.jpg   IMG_20160107_071607336_HDR.jpg
    Manheim, PA
    5,759
    I run weight in original forks with OEM springs. aftermarket springs I use 5 weight. I just run maxima. It's at about every dealer you walk into for a few bucks.
    Oct 2013
    Wherever I May Roam
    3,757
    Did you double-wall that downtube? If not, your new gusset is going to transfer the load and make it crack there even faster than it already does.
    Edit: I see now that you did double wall the down tube. Good work.
  15. #30
    Feb 2015
    82
    The frame and swingarm are painted. Now things can start going together.
