Results 1 to 15 of 25
Thread: Goki
    Jan 2011
    Choctaw, OK
    2,755
    Goki
    I'm sure most of you know what GOKI is. I had sent a message to Terry at GOKI last night asking for some technical information. This is the response I got:
    I am sorry, I can't help you Goki is another one of Obama's victim's
    Terry
    On 12/29/2015 7:30 PM, James Baldwin wrote:
    Hi Terry,
    Do you have a PDF copy of the ATC-105 installation instructions? I have an 1984 ATC 200S I bought and the Goki wiring is all hacked up. Also, did the kit include a longer decompression cable? I would like to get this straightened out and working.
    Have a great day.
    Jim Baldwin
    So GOKI is gone............
    shovelryder's Avatar
    shovelryder is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Nov 2012
    Buffalo, MN
    427
    Sure it's the presidents fault. He had it out for goki.
    6,818
    I ordered a kit for a 350x and got no response for a few weeks , finally made a phone call and they said the owner of the company is real sick and closing up for good .
    Order canceled .
    Oct 2013
    Wherever I May Roam
    3,757
    Victim.
    Lol.
    devore,ca
    1,056
    Crap .I need a new starter for my wifes 350x. Has anyone else have the shaft break ?.
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    86 350x-WHITE (with Goki)
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    2006 Arctic Cat Prowler
    RZR XP 900
    Jun 2013
    Oceanside, CA.
    617
    damn, just when I wanted to order the needed parts to complete my 350x kit.
    "HJ" Click image for larger version.
    ’84 YT60
    ’89 TRX250R (stock )
    ’90 LT500 Quadzilla
    Jan 2011
    Choctaw, OK
    2,755
    What are you short Harry
    Jun 2013
    Oceanside, CA.
    617
    Quote Originally Posted by Flyingw View Post
    Jim, picked up a used one from a member earlier this year at the Invasion and don't know if I have all the needed parts to install on a motor. Do know that the ring gear had damaged teeth the PO weld repaired so was thinking about purchasing a new one. Instruction sheet directions would be helpful too.
    ’84 YT60
    ’90 LT500 Quadzilla
    6,818
    I have a good Goki 350x ring gear if you need one .
    Quote Originally Posted by HairyJR View Post
    Were most of the GOKIs' not so reliable??
    Jan 2011
    Choctaw, OK
    2,755
    have the full installation package. I picked up all the Goki stuff a buddy of mine had (350X). Let me sort through it all and see whats good and what bad.
    Jan 2011
    Choctaw, OK
    2,755
    Ok Harry, I have two 350X Goki stator covers, one 350X flywheel with a good ring gear on it, one spare new ring gear, full installation package, and battery box with the solenoid. I also have misc cables, push button, and brackets. What I don't have are starters, and the pigtail you plug in to the tail light wire to charge the battery. What do you need?
    Jun 2013
    Oceanside, CA.
    617
    Thanks Mike for the offer. As we know the stators and flywheels are different 85 to 86, will the ring gear fit either flywheel? Jim I have the starter, cover, battery box, solenoid, push button and a cobbled up mess of a couple yellow and blue wires (might be the pigtail). Installation instructions would help me clarify any other possible missing components. Whats the pigtail look like (picture) and its make-up to change the electrical current to DC voltage? sorry for the high-jack.
    ’84 YT60
    ’90 LT500 Quadzilla
    devore,ca
    1,056
    I believe the ring gear is the same, it's the mounting flange on the starter that is different. One moves the starter closer to the center line of the engine ( I think the '86 flywheel is closer to the center ).
    YAMAHA 450 HYBRID
    85 350X- RED
    85 350x -BLACK
    85 250r
    83 atc 70
    84 atc 70
    84 atc 110
    09 yfz 450
    RZR XP 900
    Jun 2013
    Oceanside, CA.
    617
    Thanks Bob, adds another variable to installation. To understand your statement, due to the construction of the '86 flywheel the ring gear is positioned further along the crankshaft tapper closer to crankcase. This would then make the gear tooth pitch centerline engagement shallow, just catching the tips.
    ’84 YT60
    ’90 LT500 Quadzilla
