My 350x project is finally running
It's been almost 2 years collecting parts and trading to build my 350x. It's by no means a show stopper. Top end has a 1mm over sized 12:1 high compression piston. Lend up using a 400ex carb the orginal was toast needed a rebuild. Lapped each valve with new seals. Happy to say it's running and sounds great just need to work on the smaller items in time. Big thanks to Eric Joe and Jason for the time in effort to making this project go.
Looing good! What did you do for the airbox?
Thanks
I used the stock air box. Missing some parts but I made both insulator boot and air box hose fit the 400ex carb.
I soaked the insulator in hot water a few times then twisted it onto the carb. For the hose it took alittle more work. I used my soldering torch on low heat and worked it around and inside the boot to fit the carb.
//ArrowChat Integreation Code
