Whats a good/best air filter to run in my 1984 Honda 200s?
Probably a UNI Filter, That's what I run in my 350x.
'85 ATC350X
'85 ATC110
'85 ATC200X (gone)
'84 ATC125m (gone)
'86 Tecate 250 (gone)
Thanks. Ive heard good things about UNI. What about K&N? Or do they allow to much dirt in the motor?
Properly oiled UNI for wet/muddy conditions.
you can get away with a K&N for gravel road riding or dusty conditions. Needs to be oiled properly as well.
Ok. Thanks I don't plan on getting this thing muddy a lot or drowned in water. Just want to fix it up nice as i can and cruise dirt roads.
Now if I do go with a UNI or K&N I won't need to use the factory metal air filter cage right?
you will not need the factory metal cage if you buy an aftermarket filter.
Ok thats what I thought but just wanted to make sure. Appreciate the your time and the help.
Last question just to make sure. Am I gunna have to rejet my carb if I install a UNI or K&N?
OK ill hang on to it. What about rejeting my carb?
No need to jetting your carb.
huh....those filters flow more air than stock. Yes, you will likely need to re-jet. Pilot should be a 35 or 40 and I think main is a 108. Go to jets r us and pick up a 112 and 110 main. If its a 35 pilot pick up a 40. Start rich and work leaner. with just an air filter mod a 110 should be sufficient.
Ok thanks.
