Thread: '84 200es axle bearings replacement
    May 2015
    Watford city, North Dakota United States "THE BAKKEN" / Lebanon, Oregon United states.
    1,081
    Hey does any one know how to change bearings in a big red? It's got the diff wobble wobble. And any videos of this would really help
    Sent from my HTC6500LVW using Tapatalk
    Saying "it's the trikes fault" is like saying "guns kill people"
    don't poke the bear... you'll get banned
    Oct 2008
    NB, Canada
    852
    If you gotta replace all the diff bearings, it can be a bit of a job, but usually just the bearing on the brake drum cover goes. It's just a regular sealed bearing, while all the diff bearings run in the gear oil.
    Rides:
    1985 250sx
    1982 ATC185s
    1984 200es
    Always Hoping For a Maritime Trikefest- http://www.3wheelerworld.com/showthr...s-where-you-at
    "Wear Limits Are Just A Suggestion"
    May 2015
    1,081
    I think it's just the bearing in the brake drum. Do I have to take the axle off to replace the bearing?
    honda4h's Avatar
    honda4h is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    ottawa ontario
    361
    no just the drum cover
    Scootertrash's Avatar
    In the sticks
    4,638
    Are you sure the wheel hubs aren't just sloppy on the axle splines?
    The manual will have all the information you need.
    May 2015
    1,081
    Ya I'm pretty sure my 225dx does the same thing.
