Results 1 to 1 of 1
Thread: Alive again
    loganm is offline Competing with a gnat in reading comprehension. Current winner: Gnat. Arm chair racerAt the back of the pack
    Jun 2015
    Kansas
    364
    Alive again
    Cylinder got a hone job, same size piston, crank bearings were replaced with some quality ones, and it's alive again. Stator cover is off because... it kicked back first time I tried to fire it. Retarded the timing a bit, should probably set it correctly before I ride it. I have not done a leak down test yet, however, I can feel it compress on the compression stroke and the combustion stroke. Should still probably do a leak down test though.
    Video is sideways, youtube is working on it.
    +5 hp on this one... at the wheels
    heat cycle one
    Edit: what is the operating temp range on these? And can anyone explain why the temperature rises noticeably faster ~195 (.5 F a second) vs 100 (1.5 sec .5 f approx)
