So...8 months later and I'm still having front brake woes. The only issue I have had with this trike is soft front brakes. The caliper has been rebuilt and the master as well (twice). And when I say "soft" brakes, I mean about 50% and I can pull the lever to the grip. SOME resistance, but not NEAR enough.
I have reached the end of the internet searching and reading brake bleeding threads and have tried every single technique that I have found.
So far I have manually bled through the bleeder. Bled the top banjo, bottom banjo, then the bleeder. I have gravity bled and even reverse bled. Tried taking the caliper off the rotor and slowly turning it (maybe a bubble behind the upper piston) while reverse bleeding. I've worked the lever while turning the bars stop-to-stop and even left the bars on each stop for hours at a time hoping for bubbles to rise. Oh...and vacuum bled multiple containers of DOT-4 with the Mi-T vac.
I'm at my wits end and even enlisted the advice of some very seasoned veterans in the trike world and am literally stumped.
The only variable that I haven't addressed is the brake line. I bought a reproduction OEM line off eBay which looks dead-nuts on, but I have no idea how well it functions.
http://www.ebay.com/itm/HONDA-ATC-25...OVne-X9X9t1pCA
The only reason that I am questioning it is that I haven't read any reviews on it and the fact that there is quite a bit of expansion in the line under pressure. All along the line, I can feel feel a considerable amount of expansion with the lever pulled and it even contracts in length.
Before I pull the line off and try something else, does anyone have any insight into what I might be missing or even about this brake line that I have installed?
Thanks fellas...if I had any hair left, I would have pulled it all out by now!
Sent from my iPad using Tapatalk
