Thread: big red carb
    ac10 is offline New to the board Arm chair racerNew to the board
    Nov 2015
    manitoba Canada
    12
    big red carb
    85 Big Red 250 does the choke plunger control air or fuel.....seems to me that the small shaft at the end of plunger is just a guide........since Iam having a cold start issue researched this problem........the starting jet is a 2 step design..large end is 2mm and the small end is .8mm. Someone said to try drilling the jet larger so drilled to .9mm. There was small improvement but cant seem to get the fast idle....carb is clean..Thanks for any info...
    Sarnia, Ontario, Canada
    3,415
    When the plunger raises it allows fuel to pour directly into the carb Venturi.
    So to directly answer the question it controls fuel.
    There is an old Honda service bulletin about drilling out the jet where the needle seats to correct cold start issues.
    Current toys..
    1986 Honda 350X..trail bomb!
    Current non-trike toys:
    1990 Honda TRX300FW
    1995 Seadoo GTX
    1998 Polaris Touring 500
    1998 Club Car (electric)
    Jan 2011
    Choctaw, OK
    2,755
    Everything you need to know about the cold start mod is in my tutorial. http://www.3wheelerworld.com/showthr...54#post1257154
    The Open Road
    4,729
    Awesome tutorial! That needs stickied somewhere convenient.
    Sent from my Z998 using Tapatalk
    Nov 2015
    manitoba Canada
    12
    ok thanks so it is fuel
    Nov 2015
    manitoba Canada
    12
    thanks...great info
