is the 200x front end a direct bolt on to 85 250 sx??does it matter what year 200x front end?
1st gen 200x bolts on, but doesn't include a steering stop. You run the risk of denting your gas tank unless you weld on a metal steering stop on the frame neck. It is a very nice upgrade.
- Frank
1984 200ES Big Red
1985 350X (x2)
1986 350X
1986 250SX
1984 Auto-X
1984 ATC70
1985 ATC70
same neck bearings?
My current SX has a full 1st gen 200x front end on it. The 1st SX I bought had 200x forks in the stock SX triple clamps with the stock SX front wheel and drum.
Edit: I just remembered my 1st SX did not have a functioning front brake due to the X forks. The machined piece you need to hold the drum in place is not there.
