Auto X carb issues
Hi I recently did an auto 200x project the bike ran fine when it was in the 200s but after I changed everything over to the 200x it doesn't want to start hardly and when it does it stays wide open I've tried 4 different carbs on it including a brand new carb and they all do the same thing I'm at a loss here any help would be greatly appreciated thanks
Does it run better or worse with choke on?
Feedback for yaegerb:
Click Here
It would only run with choke on but high reved like it was full throttle
Concerning it reving high on startup; are you sure you aren't putting your slide in 180 degrees opposite of what it should be? It will slide in either way, only one way is correct. If you do have it 180 out they rev to the moon when you try to start. Double check that before anything else.
Click Here
Still the same thing but I have a lot of play in the throttle don't know if that's normal or not but could my throttle be bad by chance?
might be bad. got a pic of what the slide/needle/spring look like? Also, what size jets are in the carb you are currently using?
Click Here
Had stock jetting bu we ended up getting the carb fixed turns your the air screw needed to be adjusted some and the throttle cable was actually broke
//ArrowChat Integreation Code
