Results 1 to 3 of 3
Thread: 200x sprocket swaps
    Oct 2014
    tn
    110
    200x sprocket swaps
    Hey all getting time to get some new sprockets, but I have a couple questions before I buy. As of now I have stock gearing on my X. I am running 20in tires and will be going to an 18in. I am looking for more topend than what I have now. Will be going back and forth on tires, so what would you fellow trikers suggest.
    the only time I will be easy is when I'm killed by death
    Jan 2014
    Massachusetts USA
    783
    Change out the front sprocket for one with 1 or 2 teeth more. That should probably get you where you want to be, with the added benefit of less wear (smaller sprockets wear faster) and it's cheaper than changing the rear.
    1985 Tri-Z 250
    1985 ATC250R
    RUNMEDOWN is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jun 2006
    Omaha Nebraska
    319
    Gen rule is every 1" tire size change = 4 teeth rear sprocket differance. Every 1 tooth on the front = 3 rear teeth.
    More teeth on the rear = more grunt, less top end
    More teeth on front = more top less grunt.
    I am running a 30 rear with 11 front (200e Auto-X) with 18 inch tire = very near stock overall. That should give you an idea.
    85 ATC110 - The Greatest ATC of all time - (My First - new in 85)
    83 FL250 - Odyssey w/420cc - SOLD
    82 185s -10.25:1 piston, Full 200x upper, Goki Electric start - SOLD
    84 200x - Auto-X - Weisco Hi-comp, Cam'd, Bassani'd, Westcoast swinger, -SOLD
    82 200E Big Red -SOLD
    85 ATC250ES Big Red - Snow Plow !
