I'm begging for help!
84 200x
Air box lid delete
Uni filter
Header
Richter exhaust
Ok my issue is while cruising all gears it back fires/misses. Full throttle runs fine, but once it's hot, won't idle unless idle screw is all the way in. It is extremely rich and wet spark plug with the factory 108/40 jets. Air/fuel screw 2 1/4 turns, needle 4th clip. I've recently dropped to a 102 and no change. It should be lean at 108 with the air lid and exhaust not rich. I've checked my intake, only thing I can think of is the timings off, not sure if that will cause my issues!
Please help, I'm about to give up!
